General
General
Whether importing trace points on a PCB through external data or importing copper metal components through spaceclaim and modeling Cu components explicitly using contacts can give better results?
    • FAQFAQ
      Participant
      Modeling trace points on PCB layer mesh using external data gives an approximate equivalent material property representation on each element. Modeling the Cu trace geometry with contact will constitute a higher fidelity representation and so will be more accurate method and provide more detailed information in calculated results. It doesn’t involve any approximation.
