Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantIf one click on the model cell on Properties, before generating it from the cdb external model, there is an option under the “length unit” option called “object renaming” which you can turn to “off”.
