March 17, 2023 at 8:59 am
FAQParticipantWorld Origin shows the X, Y, and Z zero location in designs and drawing sheets. By enabling this feature, you can display the axes that set the default orientation of the design in the Design window. In SCDM, you can turn on the world origin by selecting the World Origin checkbox in the Show group on the Display tab. The position of the world origin cannot be changed, but geometry can be moved up to, or dimensioned from the origin.
