March 17, 2023 at 8:59 am
FAQParticipantThis procedure may be used to locate the SpaceClaim backup files or error log files: – From the Windows Start menu… In the Entry field “Search Programs and Files” Enter: %APPDATA% …An Explorer Window will open – Confirm you are in the folder: C:Users{user_login_name}AppDataRoaming – Open the SpaceClaim folder – The following folders containing the various files will be present: AcisJournals Autosave Journal Files Log Files PolygonicaJournals
