Tagged: 2020 R1, General, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantAll WB Verification Files (Fluid and Mechanical) can be downloaded in customer portal. Download > Current Release > Tools. See attached picture
