Where are ANSYS fonts stored on Windows and UNIX? In ANSYS MAPDL, under “Utility Menu > MenuCtrls > Font Selection…”, users may change the fonts used in the ANSYS GUI. However, where are these fonts stored on Windows and UNIX?
- MenuCtrls > Font Selection…”, users may change the fonts used in the ANSYS GUI. However, where are these fonts stored on Windows and UNIX?" target="_blank" rel="nofollow" title="LinkedIn">
- MenuCtrls > Font Selection…”, users may change the fonts used in the ANSYS GUI. However, where are these fonts stored on Windows and UNIX?" target="_blank" rel="nofollow" title="whatsapp">
- MenuCtrls > Font Selection…”, users may change the fonts used in the ANSYS GUI. However, where are these fonts stored on Windows and UNIX?" target="_blank" rel="nofollow" title="reddit">
- MenuCtrls > Font Selection…”, users may change the fonts used in the ANSYS GUI. However, where are these fonts stored on Windows and UNIX?" target="_blank" rel="nofollow" title="facebook">
Tagged: 17, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantRegarding font settings, these are saved in the following location on Windows: C:Program FilesANSYS Incv170commonfilesFonts On Unix: ~/.ansys/ansys17.0/ansys17.0.reg Replace the version number as necessary. For older versions of ANSYS (v8.1), the locations for Windows is: Windows registry [HKEY_USERSxxxxxSoftwareAnsys, Inc.ANSYSANSYS 8.1GUIFontsuserFonts] On UNIX: ~/.ansys/ansys8.1/ansys8.1.reg
