When using the ADAMS.MAC macro to generate MNFs (Modal Neutral Files) for ADAMS/Flex, the resulting file is very large. What can be done to reduce the file size?
March 17, 2023 at 9:00 am
FAQParticipantThe MNF can be optimized in the ADAMS/Flex Toolkit program, such as computing the inertia invariants, removing internal element faces, and/or using single precision. The procedure can also be performed when generating the MNF with the ADAMS.MAC macro by setting the system environment variable MDI_MNFWRITE_OPTIONS. The values of this system environment variable is a comma-separated list, which includes “single” (single precision), “fast_invar” or “full_invar” to pre-compute the partial or full set of invariants, “strip_face” to remove internal element faces, and “coarsen(res,ang,colin)” to coarsen the mesh based on a ‘percent resolution,’ ‘tolerance angle,’ and removal of ‘colinear points’ (0 < res < 0.5, 0 < ang < 45, colin=0, 1). Please refer to the ADAMS/Flex documentation ("Setting Up Translation Options through the MNF Toolkit") for details on all supported options.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
