When using multi linear plasticity model, is it possible for von Mises or max principal stress to go beyond ultimate stress?
January 25, 2023 at 7:34 am
FAQParticipantEquivalent stress must follow the stress-strain curve. For metal plasticity by definition we use the von Mises equation (a.k.a. equivalent stress) to relate the stress tensor to a scalar quantity that we match to the input multilinear stress-strain curve. Maximum principal stress will not follow the stress-strain curve. It is definitely possible that maximum principal stress will be above ultimate stress if the hydrostatic component of stress is large.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
