When the material data sheet of a polymer reports both the Tensile and the Flexural Modulus, which value may be used in place of Young’s Modulus?
Tagged: 18.2, materials, mechanical, Polymers, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantIn general, both the Flexural and Tensile Modulus are used as Young’s Modulus of the material under Flexural (bending) and Tensile deformations respectively. For most metals at small strains, there is no much difference between these two values so either of them can be used as Young’s Modulus in simulations. For polymers, due to their nonlinear material behavior, these numbers need not be the same. In that case, it is recommended to use Tensile Modulus as Young’s Modulus of the material.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
