When performing a fracture analysis with a pre-meshed crack, the simulation stops before calculating any fracture-related results and in the solve.out the following warning and error messages are issued: *** WARNING *** CP = 100.078 TIME= 10:16:56 Fracture parameter calculation issue: crack tip node is attached to element type that is not supported, Crack 1, crack tip node 428118, element type 14. Element will be ignored. *** ERROR *** CP = 103.062 TIME= 10:16:59 Crack front provided for crack # 1 does not have a contiguous set of nodes. If SOLID186 and SOLID187 are the only elements that comprise my mesh, and they are supported within fracture analysis, then why am I getting this error?
Tagged: 18, fracture, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantThis error is due to the presence of weak springs in your model. Element type 14 refers to COMBIN14, which is the spring-damper element used for implementing weak springs. The solution is to turn weak springs off in Analysis Settings –> Solver Controls. If the solution fails to converge after weak springs are turned off, then you will need to take corrective action to properly constrain your model. Note that the weak springs annotation will not be shown on the graphical display due to the simulation failing before at least one substep is successfully solved.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
