When left click on model, red ball didn’t appear and couldn’t set center of rotation. How to set the center of rotation?
June 5, 2023 at 7:04 am
FAQParticipantOn the WorkBench, go to Tools >> Options > Graphics Interaction. In the details of ‘Pan,Rotate and Zoom’ option, check the box for “Use Spaceball”. The rotation center should appear now when left click on model.
