Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThe Convergence object is applicable to Static Structural, Modal, Eigenvalue Buckling, Steady-State Thermal, and Magnetostatic analyses. Note the following requirements: Only one Convergence object is valid per result object. Convergence is not supported: For result objects that belong to linked analyses.If an imported load object exists in the environment. When Imported Plies or Imported Thickness objects are used. Also, Element Orientation would make convergence not available.
