Tagged: 12, fatigue, General, materials, Mechanical APDL (f. ANSYS), structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantStress-life fatigue generally applies to low stress, high cycle fatigue where the general membrane and bending stresses do not exceed the material yield stress. Stress-life is generally still applicable, even if pseudo-elastic, local peak stresses exceed the yield stress.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
