When I visualize droplet properties in Fluent mass and heat transfer number appear to be negative. Is that possible?
June 6, 2022 at 8:33 am
FAQParticipantNegative heat or mass transfer numbers are indeed physically possible and can happen if the concentration of the evaporating specie(s) in the gas phase is higher then the saturation concentration. Physically, this corresponds to liquid condensing back onto the droplet, but ANSYS Fluent built-in DPM mass and heat transfer models do not model this condensation. The negative values for mass and heat transfer are therefore only relevant for post-processing.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
