When I try to Execute my model, it shows “”wrapup cycle or time already exceeded”” even at cycle zero.”
Tagged: 17, autodyn, Explicit - AUTODYN, General, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantAt cycle zero, this message reminds you that the wrapup cycle or time in your problem has not been specified. You should specify the cycle limit or time limit of your calculation in the Wrapup Criteria option in the Controls panel. After that, save your problem and then press the Run button again. AUTODYN will then execute.
