When I import an stl file (created in mm units) into SC, my geometry scale is not correct. How do you fix this? Setting the general ‘Units’ to ‘mm’ from Utility Menu =>File=>Space Claim Options =>Units=>Length=’mm’ has no effect.
- File=>Space Claim Options =>Units=>Length=’mm’ has no effect." target="_blank" rel="nofollow" title="LinkedIn">
- File=>Space Claim Options =>Units=>Length=’mm’ has no effect." target="_blank" rel="nofollow" title="whatsapp">
- File=>Space Claim Options =>Units=>Length=’mm’ has no effect." target="_blank" rel="nofollow" title="reddit">
- File=>Space Claim Options =>Units=>Length=’mm’ has no effect." target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 8:59 am
FAQParticipantSetting the general ‘Units’ to ‘mm’ from Utility Menu=>File=>Space Claim Options=>Units=>Length=’mm’ is not enough. You also need to set …SpaceClaim Options => File Options => STL=> Units: ‘Millimeters’
