When I do a nummrg command on keypoints I get the message: *** WARNING *** CP= 4.026 TIME= 13:36:55 After NUMMRG,KP, node 140923 (and possibly others) is associated with more than one solid model entity. Future commands which depend on the node to solid model connectivity (meshing, mesh clearing, solid BC transfer, etc.) may not operate properly. Node 140923 is not associated with any of the keypoints that were merged. However, this node is associated with a hard point. Why am I getting this warning?
Tagged: 17, General, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 316237.pdf
