When I change the parameter in SCDM, the geometry change is updated in Mechanical. But the parameter set value does not update?
April 5, 2023 at 2:31 pm
FAQParticipantWhen parameter value is changed from Spaceclaim, it can update the Mechanical model. But the parameter set value in WB is not updated. To update, there is an option ‘Update Parameter’ in Spaceclaim under the ‘Workbench’ tab. This will push the updated value to Parameter set.
