April 5, 2023 at 2:31 pm
FAQParticipantPlease check your graphics card supported or not for the ANSYS version. You can find the supported graphics list for latest version at; https://www.ansys.com/-/media/ansys/corporate/files/pdf/solutions/it-professionals/platform-support/graphical-display-graphics-cards-tested-192.pdf?la=en
