When doing submodeling in Mechanical, the second cut boundary constraint is shown graphically in Mechanical, and the mapping looks right. However, the constraint is not written in the input file. Is that a defect?
June 5, 2023 at 7:04 am
FAQParticipantNo, The second set of constraints are not written because both cut boundary constraints are applied at common nodes and override constraints is set to NO. Setting override constraints to Yes on Imported Cut Boundary Constraint allows for both constraints to be applied.
