When comparing solution performance of differing computers why does computer A outperform computer B?
Tagged: 18, General, mechanical, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantSolution performance difference is possibly due to the CPU’s being of different families. See attached PDF for more information.
1. MechanicalAPDL-CPUFamily.pdf
