When changing the Exposure Duration under the details of the Fatigue Tool for a Random Vibration analysis, the Damage contour plot values change correctly but the Life plots remain the same. Why?
Tagged: Damage contour plot, Life plot, random-vibration
June 6, 2022 at 9:58 am
FAQParticipantThe Mechanical Fatigue Tool uses a slightly different method to calculate life (comapared against Ansys nCode DesignLife). For Damage, the Mechanical Fatigue Tool uses Exposure Duration in the same manner as DesignLife. Essentially, it calculates the Damage in seconds and then multiplies that result by the Exposure Duration to determine the total damage. To calculate the Life, the Mechanical Fatigue Tool takes the reciprocal of total damage (just like DesignLife), but then it multiplies that quantity by the Exposure Duration. The net effect is that Exposure Duration used in the Damage calculation is canceled out in the Life calculation and the Fatigue Life is always reported in seconds, regardless of the specified Exposure Duration. If you check the Details Window under Life, you will see that the Life is reported in seconds, regardless of the specified Exposure Duration.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- Hyperelastic Simulations
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
