When a model takes a lot of substeps to converge, the force/displacement convergence plots get crowded and gets difficult to monitor the convergence pattern towards the end. Is there a way of zooming into a portion of this plot?
Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThe user can hold CTRL + Alt keys and use the LMB to draw a box from top left to bottom right corner to zoom into a portion of the curve; similarly draw the box from top right to bottom left to zoom out. Alternatively, the user may also input the number of displace points under the details of Solution Information (default set to All) to display a specific number of iterations at a time.
