What’s the difference between the MP and MPDATA commands when defining a material property as a function of temperature?
Tagged: 18, materials, mechanical-apdl, Special Purpose, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantWhen a material property is defined with MPDATA command (e.g. MPDATA,EX,MAT,1,c0,c1,c2) each value (c0,c1,c2,c3,c4) corresponds to the property at the MPTEMP temperature (MPTEMP, STLOC, T1, T2, T3). Thus, the property table is associated with the temperature data table. On the other hand when MP command is used (e.g. MP,EX,MAT,c0,c1,c2,c3,c4) a fourth order polynomial as a function of temperature is defined: Property = C0 + C1(T) + C2(T)2 + C3(T)3 + C4(T)4
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
