Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantWhen color display issues occur on the model due to customization of the legend, one should use the “High Fidelity” option in the legend settings. For example, when you are interactively probing a contour result that has a customized legend and the interval between adjacent bands is much smaller (at least less than one thousandth) compared with the full min-max range, this option replots and improves the synchronization of the values of the probes with the colors on the model as well as the corresponding color/range in the legend. The “High fidelity” option can be activated through a right-mouse button click on the legend and select “High fidelity”.
