What method should be used to export both thermal and structural loads to CFX from an ANSYS thermal/structural analysis?
March 17, 2023 at 8:59 am
FAQParticipantExporting information from ANSYS to CFX is accomplished by using the EXPROFILE command. Specify a unique filename for each profile file.
