Tagged: 2019 R3, engineering-data, General, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantGranta selector is used for comparison, selection, and substitution of materials. Also acts as an index to the full Granta data library – find the right material type using MaterialUniverse, then dig into detailed data in specialist datasets.
