What is the slope of the multi-linear hardening plasticity curve beyond the last user defined stress/strain value?
June 6, 2022 at 9:58 am
FAQParticipantThe slope of the multi-linear hardening plasticity curve beyond the last defined stress/strain value is zero, or in other words the material behaves as a perfectly plastic. This is the same case with both the kinematic and isotropic hardening models.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
