Tagged: 17.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantThe Static tab allows the user to identify a result set to be used as a static offset to the alternating stresses developed by the Time Series load mapping. The stress from that load case will be treated as a static stress superimposed with any varying stresses.
