What is the meaning of the “Out of memory” error when using the DDPM-DEM Model in ANSYS Fluent and how to fix this?
Tagged: 17, dem, fluent, fluid-dynamics, MP - Particle Tracking, multiphase
March 17, 2023 at 1:11 pm
SolutionParticipantFluent uses a virtual Cartesian mesh to evaluate the DEM collisions. The size of the virtual mesh is dependent on the parcel diameter used in the DDPM model. If the parcel size goes too small, the resulting virtual mesh may become extensively huge to be handled by the system, resulting in the “Out of memory” error. To overcome this error, the parcel diameter needs to be increased. A larger parcel results in a reduced virtual mesh cell count. For a fixed mass of the particle-phase in the domain or a given particle injection mass flow-rate, this can be achieved by reducing the number of injected parcels in the domain. This effectively increases the mass per parcel (and consequently the particle number per parcel), thereby increasing the parcel diameter. A more detailed discussion on this aspect can be found in the attached pdf.
1. 2044368.pdf
2. 2044368.zip
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
