January 25, 2023 at 7:34 am
FAQ
Participant“Expected Frequency” is commonly used in PSD fatigue calculation in aerospace applications. The Expected Frequency is provided as an approximation to zero crossing frequency (ZCF) commonly used in narrow band PSD fatigue calculations. It is calculated as the centroid of the area under a response PSD curve. Depending on the shape of response PSD curves (caused by the dominating modes), the calculated Expected Frequency can be conservative or unconservative comparing to the ZCF. Therefore, the Expected Frequency solely provides a “ballpark” value for users to make adjustment for either conservative or non-conservative estimate of fatigue life calculation. As a side remark, the ZCF is calculated as sqrt(m2/m0), in which m2 is second moment of area of response PSD while m0 is zeroth moment of area of response PSD. By virtue of random process theory, it is also equal to (Stress Velocity RMS / Stress RMS). Since Mechanical doesn’t provide it as a standard result, the Expected Frequency is just a quick solution alternative that the users requested above. I agree that the statement “Statistically, it is the mean frequency that is often used in the random vibration fatigue life calculation.” is misleading to users in terms of definition of ZCF. The statement was actually removed from ANSYS Help 17.1.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
