April 13, 2023 at 7:33 am
SolutionParticipant“Type of damping” is governed by the underlying loss phenomenon and determine how the system will behave. If correctly abstracted, they represent true physical behaviour: 1. Cases where natural frequency reduce 2. Cases where natural frequency increase Please refer to the attached files to access the solution. Keyword: Natural Frequency, Damped Modal, Damping; Structural damping, Hysteretic damping Viscous damping, DMPR, DMPS
1. 2057781.zip
2. Solution_2057781.pdf
