January 25, 2023 at 7:34 am
FAQ
ParticipantFollowing is the explanation from ANSYS help; True Status: Uses the current contact status from the restart snapshot. If the previous run for parent static structural is nonlinear, then the nonlinear contact status at the point of restart is frozen and used throughout the linear perturbation analysis. Force Sticking: Uses sticking contact stiffness for the frictional contact pairs, even when the status is sliding (that is, the no sliding status is allowed). This option only applies to contact pairs whose frictional coefficient is greater than zero. Force Bonding: Uses bonded contact stiffness and status for contact pairs that are in the closed (sticking/sliding) state.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
