Tagged: materials, mechanical-apdl, Other, Special Purpose, structural-mechanics
May 15, 2023 at 8:33 am
SolutionParticipantModified strain hardening is the integral form of strain hardening assuming constant stress, so they are essentially the same for constant stress case, only difference is the calculation of creep strain, MSH will be more accurate regardless of time step. For none constant stress cases, they are just two models that fit to experiment, although they will likely closer to each other in the response. See attached pdf for more rigorous explanation.
1. 2056325.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
