June 5, 2023 at 7:05 am
FAQParticipantFor pure rigid bodies, indeed, both solvers have been validated against each other, but RBD is fundamentally formulated for large motion and large rotation and highly non linear solutions. That implies: – Robust strategies for adaptive time stepping, whether it is using implicit or explicit time integration (as a matter of fact, since 17.2, for contact dominated models, the MJ time stepping algorithm is the recommended method, and is implicit!) – Dedicated techniques to deal with very large rotation increments over one step – High fidelity: Consistent tangent matrices, energy conservative integration schemes, Lagrange multipliers formulation for contact, full non linear formulation of equations of motion. – Allows for loads dependent on model state – Solver tuned for relatively small number of degrees of freedom but large number of time steps.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Tips about Postprocessing options for Harmonic Solution in Mechanical
