Tagged: 2019 R1, act, ANSYS Customization Suite, Workflow Technologies
March 17, 2023 at 2:15 pm
FAQParticipantThe default folder to install your script ACT extension is: C:Program FilesANSYS Incv193AddinsACTextensions Save your extension in this folder (.xml + folder of the extension), then it should be available in the Workbench extension manager (after restart) You can also have an additional folder to install your extension. It is in the Workbench ‘Tool’ menu > Options > Extensions.
