June 5, 2023 at 7:05 am
FAQParticipantMega word is memory unit used in LS-Dyna. Word defines as the number of digits a CPU can process at a time. It depends on platform. Nowadays 64 bit OS are used mostly. Thus 1 word = 64bit = 8 bytes
