January 25, 2023 at 7:34 am
FAQ
ParticipantMass moment of inertia is a scalar value which tells us how difficult it is to change the rotational velocity of the object around a given rotational axis. When a mass moves further from the axis of rotation it becomes increasingly more difficult to change the rotational velocity of the system. Intuitively, this is because the mass is now carrying more momentum with it around the circle (due to the higher speed) and because the momentum vector is changing more quickly. Both of these effects depend on the distance from the axis. If the assembly represented by the point mass has a small volume or concentrated mass, you may not have to input mass moment of inertia for the point mass because Ixx,Iyy and Izz are small enough to be negligible. If the assembly represented by the point mass has a widely distributed mass, then moment of inertia should be included because it may significantly affect the results. Because mass moment of inertia is part of mass matrix, higher mass moment of inertia generally leads to lower natural frequency.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
