April 5, 2023 at 2:32 pm
FAQParticipantSupplemental licenses are HBM Prenscia licenses that are used with an ANSYS nCode DesignLife license. They allow ANSYS nCode DesignLife users to access to HBM Prenscia tools that are not supported by an ANSYS nCode DesignLife license (e.g., signal processing capability within Glyphworks). They are purchased from and supported by HBM Prenscia.
