Tagged: 17.2, apdl, General, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantPlease refer the following link in ANSYS Help Viewer on APDL as a Macro language: help/ans_apdl/Hlp_P_APDL4.html or in ANSYS Help go to // Mechanical APDL // ANSYS Parametric Design Langauge Guide // APDL as a Macro Language
