March 17, 2023 at 9:00 am
FAQ
ParticipantThe Newmark accelerations can be noisy for many problems. The Newmark assumption uses the average acceleration [(a(t) + a(t+dt))/2] in its calculation. Initial conditions and nonlinearities can cause the values at “t” and “t+dt” to oscillate (sometimes wildly). Rather than reporting these accelerations in the output, when AVSMOOTH is 1, we report the averaged value so that a smooth solution is seen.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
