What causes the following Warning message to be issued: “material XXX has a crack softening property defined, but no failure model”?
June 6, 2022 at 9:58 am
FAQParticipantAn Explicit Dynamics system requires both a crack softening property and a failure model. The failure model is required to initiate a crack. The crack softening property is required to propagate the crack. The material failure model is defined in Engineering Data.
