What are the different ways to excite a base (with displacement or acceleration) in harmonic analysis? (MAPDL)
March 17, 2023 at 1:12 pm
Solution
ParticipantIn the attached example, 3 methods are presented for a base excitation in a harmonic analysis – The Large Mass method: used for several years, the acceleration is replaced by a force applied to a large mass fixed to the base of the model. This mass is a lot heavier than the total mass of the structure (>10^3). To replace the A0 acceleration, an equivalent force F = ML*A0 is applied. – The Enforced Motion method: available since R13 for MSUP harmonic. This method create a loadvector in the modal basis which allow to apply an acceleration or a displacement – The Full harmonic method: more accurate but also more time consuming. The displacement (or the acceleration) is directly applied threw an imposed displacement (using D command) Nota : In harmonic, displacement and acceleration are linked by the following equation : A = w².U (w is the pulsation)
1. 2040083.pdf
2. 2040083.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
