What are precautions for proper import of the models that have multibody parts dimensions in microns units?
Tagged: 18.2, General, structural-mechanics, workbench platform
April 5, 2023 at 2:32 pm
FAQParticipantThis may sound obvious but small geometries should be created using Micrometer unit system. This option in DesignModeler as well as SpaceClaim, has to be set before starting to create the geometry and if any larger unit is selected, it can not be changed later. Using Micrometers ensures the tighter tolerances in the model to ensure proper shared topology operations.
