January 25, 2023 at 7:34 am
FAQParticipant2D shell elements are like SHELL208 element and 3D shell elements are SHELL181 or SHELL281. These elements have composite capabilities however right now only 3D shells are supported by Workbench Mechanical. Also Workbench Mechanical supports only shell composite simulation directly or though ANSYS Composite Prepost (ACP).
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
