Tagged: 18, General, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantThis video is from an internal meeting on the topic of Beam-Solid and Shell-Solid Submodelling. This video and the associated presentation are made available to our customers in hopes that you will find the technical content useful. Please refer to the attachments to access the video and the related presentation.
1. 2046609.pdf
2. 2046609_Beam-Solid and Shell-Solid Submodelling.mp4
