Tagged: 17.2, General, mechanical-apdl, structural-mechanics
August 25, 2023 at 12:16 pm
SolutionParticipantThis video is from an internal meeting that highlights relevant Knowledge Material articles 2042179, 2042188 on the topic of Accurate Stresses on Surfaces. This video and the associated presentation are made available to our customers in hopes that you will find the technical content useful. Please refer to the attachments to access the video and the related presentation.
1. 2046550.pdf
2. 2046550_Accurate%20Stresses%20on%20Surfaces.mp4
