May 15, 2023 at 8:32 am
SolutionParticipantThe attached video demonstrates how to import an image file into SpaceClaim and convert the image into editable sketch curve geometry. The Vectorize Image tool is the focus of the attached video.
2. 2052888_Captions-EN.mp4
