Tagged: 17, bolt-pretension, EINTF, General, mechanical-apdl, PRETS179, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments for the solution.
1. 261654.pdf
2. 261654.zip
