User gets the following error when using ANS_ADMIN utility to “Configure Connection for Catia V5”: “Environment Creation Failed” – child process exited abnormally. What is causing this error?
Tagged: 17, General, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 317089.pdf
